L Lucky girl Reputable Oct 5, 2014 1 0 4,510 Oct 5, 2014 #1 I have an older dell monitor with dvi to hdmi adapter in use to view movies, etc. it has worked fine for months but just stopped working. The power indicator light goes from blue to orange and no image appears...I have a new power cord, any ideas?
Solution ThatVietGuy Oct 5, 2014 The orange color means the monitor went into standby mode because it doesn't detect a signal. Try using the monitor with other sources and see if you get the same problem. It can also be the cable causing your problem.
ThatVietGuy Titan Nov 6, 2007 11,726 318 70,240 Oct 5, 2014 Solution #2 The orange color means the monitor went into standby mode because it doesn't detect a signal. Try using the monitor with other sources and see if you get the same problem. It can also be the cable causing your problem. Upvote 0 Downvote Solution
