What does the led lights mean on gigabyte mb
efren mendoza
7
my computer turns on then off over and over what does that mean gigabyte gah55mud2h I5 2.66 gig what can i check i know how to build my own comp. please help i installed a new chip because i was told by geek squad but it is stil tuening on for a second then off then on over and over what should i do?
Checking the PDF file for the manual the only LED lights I see are in the top right corner and they are CPU load lights. Which show the amount of CPU usage that is going on. What is your systems current setup.
Motherboard: Gigabyte GA-H55M-UD2H
CPU: i5 but which
PSU:?
HDD:?
OS:?
Memory:?
2 sticks of 2 gig
i forgot to say the original reason it stopped working was the cpu fan cord got caught on fan blade and the computer shut off. and it started doing what i said turns on and off over and over all the led lights are comming on the motherboard that is why i replaced the cpu but it is still doing this
hmm at the top right corner right? See when I read the manual it said the lights would turn on based on how much load was on the CPU. However if all the lights are turned on I wonder if it could be CPU related. Are you able to get into the bios if so take a look at the voltages and the cpu temp.
Sounds like it could be a short -- when you installed the MOBO did you use the proper standoffs in the proper place so that the underside of the MOBO does not touch the case tray ? Also take a look under the MOBO and make sure there is not a loose screw or something caught between the MOBO and the case that is causing a short.
