G guymarshall Honorable Jan 25, 2015 549 4 11,015 Mar 23, 2015 #1 I am building my own PC and I am going to use the Fractal Design Define R5 Pearl case and I was wondering what is the best DVDRW internal drive that will fit in the case and enable me to install Windows 8.1 without USB?
Solution USAFRet Mar 23, 2015 guymarshall : USAFRet : They are all the same. Anything under $20. Ok so do they all have different sizes or do they all fit in the same space? All the same standardized height and width. Some may be a little longer or shorter than others. Performance wise...all the same.
USAFRet Titan Moderator Mar 16, 2013 179,811 22,129 184,590 Mar 23, 2015 #2 They are all the same. Anything under $20. Upvote 0 Downvote
G guymarshall Honorable Jan 25, 2015 549 4 11,015 Mar 23, 2015 #3 USAFRet : They are all the same. Anything under $20. Ok so do they all have different sizes or do they all fit in the same space? Upvote 0 Downvote
USAFRet Titan Moderator Mar 16, 2013 179,811 22,129 184,590 Mar 23, 2015 Solution #4 guymarshall : USAFRet : They are all the same. Anything under $20. Ok so do they all have different sizes or do they all fit in the same space? All the same standardized height and width. Some may be a little longer or shorter than others. Performance wise...all the same. Upvote 0 Downvote Solution
G guymarshall Honorable Jan 25, 2015 549 4 11,015 Mar 23, 2015 #5 USAFRet : guymarshall : USAFRet : They are all the same. Anything under $20. Ok so do they all have different sizes or do they all fit in the same space? All the same standardized height and width. Some may be a little longer or shorter than others. Performance wise...all the same. Ok thanks mate! Upvote 0 Downvote
