Question What fan curve settings I should do?
Jstevens5
4
I recently got a new case over the last couple days, and the fans are really loud looking to change the curve fan settings in my BIOS to make it quieter.
I’ve used furmark and have got around 72 degrees celcius for my gpu in 1440p while also using cinebench with the temperature from the attached pic after 3mins.
I have 7 points to use for the fan curve in my BIOS, what should I set them to?
Will also be getting a liquid cooler sometime soon, what should I get for that? Looking for something that’s not noisy.
Case: Antec C3 ARGB
CPU: Ryzen 7 9800x3d
CPU cooler: Hyper 212 Halo Black
GPU: 3070Ti
PSU: Corsair RM850x
Ram: KINGSTON FURY BEAST 32GB
Motherboard: B650 UD AC
You have the wrong cooler for the job. If I were you, I'd have looked into something more beefy instead of a recycled cooler by Coolermaster that's been the same design since I can remember, maybe 2 decades ago.
If you had a beefier cooler, you wouldn't have needed to adjust the fan curve nor see a bump in temps.
Mind sharing a screenshot of what you've set the fan curve to?
BIOS version for your motherboard?
Case: Antec C3 ARGB
How are the fans set up in your case? Make and model of your fans?
