What fans do you recommend for my cooltek antiphon case?
Sep 17, 2013
45
I have a cooltek antiphon with 3 stock fans placed front, front and back, all 120mm but they are a little loud. I found a noctua fan model that is really silent but it only has 600-800RPM and i'm wondering if that's enough because i also use dust filters.
Can you tell me if Noctua NF-S12A ULN will do a good cooling job for my case?
or if not please recommend me something beter. i don't really care about the price range as long as it's quality.
I'm sure those will work fine. These are also a good choice: http://www.frozencpu.com/products/9652/fan-609/Thermalright_X-Silent_120mm_x_25mm_Stealth_Silent_Fan_-_1000RPM.html?gclid=CKaE1fiX2LkCFcN_QgodJH4AcQ
These are supposed to be good and quiet too...
These are supposed to be good and quiet too: http://www.newegg.com/Product/Product.aspx?Item=N82E16835553008
Thanks for the cougar hint, i'm not going to buy that exact model you showed me but looking at it's video review i saw that it has a "big brother", COUGAR CF-V12HP, that has more airflow, less noise and more rpm and also more lifetime (300.000 hours!)
So thanks! By showing me this model you helped me a lot!
No prob! Glad to help
