What fans should i put on my cpu cooler?
JesseC123
101
My PC Specs: PCPartPicker part list: http://au.pcpartpicker.com/p/dtXdQ7
Price breakdown by merchant: http://au.pcpartpicker.com/p/dtXdQ7/by_merchant/
CPU: Intel Core i5-4690 3.5GHz Quad-Core Processor
CPU Cooler: Cooler Master Hyper T4 70.0 CFM Rifle Bearing CPU Cooler ($33.00 @ Umart)
Motherboard: Asus H97-PLUS ATX LGA1150 Motherboard ($145.00 @ Centre Com)
Memory: Kingston HyperX Fury Red 8GB (2 x 4GB) DDR3-1866 Memory ($78.00 @ Umart)
Storage: Intel 530 Series 120GB 2.5" Solid State Drive ($105.00 @ CPL Online)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive ($98.00 @ Centre Com)
Video Card: EVGA GeForce GTX 970 4GB Superclocked ACX 2.0 Video Card
Case: Corsair SPEC-03 Red ATX Mid Tower Case ($85.00 @ CPL Online)
Optical Drive: Samsung SH-224DB/RSBS DVD/CD Writer ($19.00)
Operating System: Microsoft Windows 10 Home OEM (64-bit)
Case Fan: Cooler Master SickleFlow 69.7 CFM 120mm Fan
Monitor: BenQ RL2455HM 60Hz 24.0" Monitor ($175.00)
Mouse: Razer DeathAdder 2013 Wired Optical Mouse ($49.00 @ CPL Online)
Other: Cooler Master Thunder 600W Power Supply ($73.00)
Other: Plantronics Gamecom 788 USB 7.1 Surround Sound Gaming Headset (Purchased For $85.00)
Other: Coolermaster CM STORM QuickFire TK Cherry MX Brown
Total: $1023.00
Generated by PCPartPicker 2015-08-14 22:36 AEST+1000
I am getting a CoolerMaster Hyper T4 CPU Cooler and was wondering what fans I should get. (or should i keep the stock ones??) I want some pretty quiet fans (preferably black), that can also produce some good airflow. I was also wondering what set up I should use for my cooler, push,pull or push/pull or what configuration you guys recommend?
I would get the 212 evo but it does not fit my case 🙁
Thanks
30 is the sound of a quiet library or a large empty room. Bear in mind that's only on full blast which will be pretty much never depending on how you curve your fans. PWM on the motherboard and you likely wouldn't be able to hear it over the ambient noise in the room, let alone the noise coming from your computer (PSU, for example).
There's PLENTY of other choices. The stock Sickleflow fans on most CM heat sinks aren't bad but get noisy over about 60% or so. I guess I would wait and see how noisy it is, might not need something else.
31.7 dba sounds like a pretty noisy fan, correct me if i'm wrong?
Okay, this sounds pretty promising thanks!
I will definitely be purchasing one of these HP-12's for my heatsink cooler :)
