G
Guest
Guest
<A HREF="http://www.antec-inc.com/product/cases/var_sohoser.html" target="_new"> This</A> is the case I'm getting. It's different from the other models because it doesn't come with a power supply. (I bought an Enermax Whisper 430W power supply separately). The case has 4 80mm fan mounts. It comes with 2 80mm sleeve bearing fans in the rear. There's room for 2 other fans: 1 in front and 1 near the lower hard drive bay.
Ok, now for my questions.
1) Are the 2 rear fans that come with the case any good? I can buy better fans if it's worth it.
2) What's the difference between sleeve bearing and ball bearing fans? Which is better and why?
3) Do I need to buy fans with 3-pin or 4-pin connectors?
4) Which brand and model of 80mm fans are best for around $10 USD?
5) What specific qualities should I look for in a fan? Like CFM, dBA, and RPM. For instance, look at these fans.
Sunon KD1208PTB2
39 CFM @ 32 dBA
2900 RPM
Papst 8412NGL
19.5 CFM @ 12 dBA
1500 RPM
First of all, I don't know what CFM means. I know the Sunon is louder than the Papst. But I can't tell how loud they are without hearing them first. What is the highest dBA that a quiet fan should have, before it's considered loud?
Thanks for helping this confused n00b
Sunon KD1208PTB2
39 CFM @ 32 dBA
2900 RPM
Papst 8412NGL
19.5 CFM @ 12 dBA
1500 RPM
