What FM2+ CPU is better for GTX1050 ??
Feb 19, 2018
So guys, since it bottleneck with my GPU, I want to change CPU for my FM2+ socket, but it must compatible with my GPU.
CPU: A10 7700k
GPU: GTX 1050 2GB
Motherboard: Maxsun MS-A88FE Turbo M.2
Any suggest? How if I change with FX 770k?
x4-880k is perhaps 10% stronger.
I doubt that would be worth it.
Best to start over with intel or ryzen.
$250 will buy you a G4600, lga1151 motherboard and 8gb of ddr4 ram which will be a better gamer and some 35% stronger single thread performance which is what most games want.
You already have one of the best and changing for a little better one will result in almost no performance gain a a good amount of money wasted better invested in a newer platform.
