What FPS will this computer build run games like CS GO and Battlefield 4 on medium-high settings? Also is their any problems
AidanG
OS: Microsoft 8.1 64 bit OEM
Optical Drive: SAMSUNG DVD Burner 24X DVD+R 8X
Hard Drive: Seagate Hybrid Drive ST2000DX001 2TB MLC/8GB 64MB Cache SATA 6.0Gb/s NCQ 3.5" Desktop SSHD
RAM: G.SKILL Sniper Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1866 (PC3 14900) Desktop Memory Model F3-14900CL9D-8GBSR
Processor: AMD A10-5800K Trinity 3.8GHz (4.2GHz Turbo) Socket FM2 100W Quad-Core Desktop APU (CPU + GPU) with DirectX 11 Graphic AMD Radeon HD 7660D AD580KWOHJBOX
Graphics Card: PNY VCGGTX650XPB GeForce GTX 650 2GB 128-bit GDDR5 PCI Express 3.0 x16 Video Card
Motherboard: MSI FM2-A85XA-G43 FM2 AMD A85X (Hudson D4) HDMI SATA 6Gb/s USB 3.0 ATX AMD Motherboard
PSU: CORSAIR CXM series CX500M 500W ATX12V v2.3 SLI Ready CrossFire Ready 80 PLUS BRONZE Certified Modular Active PFC Power Supply
Less than 30 frames per second in Battlefiled 4 with High settings at 1920x1080 resolution.
The GTX 650 is one level down from the HD 7770:
http://www.tomshardware.com/reviews/battlefield-4-graphics-card-performance,3634-7.html
http://www.tomshardware.com/reviews/gaming-graphics-card-review,3107-7.html
The CPU you have chosen is OK.
If you want to run Battlefield 4 with High settings at 1920x1080 resolution, recommend at least a GTX 650 Ti.
GTX 650 Ti boost is big step up from there in performance and very good value if you can afford it.
You should be fine for medium-high settings for Bf4, but CS GO, being a lot less resource-intensive, should be really easy to run. If Bf4 doesn't work in medium-high try making Bf4 render with Dx10 instead of Dx11.
