What Gaming Laptop with best battery life when it's not gaming
nandanaputra
I'm Looking for this criterion ( budget MAX 3000 AUD ) :
- 14-15,6 inch
-22MM or less for thinness
- GTX 1050 Ti / GTX 1060
- Good cooling system when it's on gaming
-Battery life more than 8 hours for general use ( i will spend a lot of time in university )
If there is no such laptop within that criteria, is there possible to charge a laptop with USB type C ? can you give me a recommendation about what kind of power bank can charge laptop through USB type C?
The best laptop for the max battery is dell inspiron 15 which as 1050ti with i7 7th gen and 8GB ram.
if the link is not working you can go to dell home page and search for: dell inspiron 15 7000 gaming, and you will get this model for around 2000$
http://www.dell.com/au/p/inspiron-15-7567-laptop/pd?oc=sma510872au&l=en&s=dhs
this laptop will provide you 7-8 hours of normal use with single charge.
Thankyou, put that on my list.
But isn't too bulky if I bring it to college ? it's 25mm.
