what gpu to get for 1440p monitor?
cvscrules
12
I am soon going to get a 1440p monitor http://www.amazon.com/Acer-G257HU-smidpx-25-Inch-Widescreen/dp/B00QS0AKVK and I figured my r9 270x isn't going to cut it. I am planing on gaming on it, but don't need an overkill just something to play enjoyable frame rates at 30-60. I initially figured that I would get like a r9 290 just because it seemed like it would get the job done, but then I started looking and it seems like every generation you go back the values get better. (If you buy on Ebay). But I don't know if its smart to buy too far back. Also I don't know if I should go ahead and join team green(nvidia). There's just so many damn options and I just would like to know whats the best price to performance GPU for me to get for a 1440p monitor.
One of the best 1440p single cards before you get all the way up to the GTX 980ti is the AMD R9 390 8G. It is a great spot in terms of price/ performance.
Video Card: MSI Radeon R9 390 8GB Video Card ($309.98 @ SuperBiiz)
Total: $309.98
Generated by PCPartPicker 2015-11-20 19:11 EST-0500
At 1440p on ultra settings you'll be looking at about an average of 50 FPS, so for a really smooth run using this card you'll probably want to be playing AAA titles on 'High'.
Total: $309.98
The GTX 980 is about $200 more expensive than the R9 390, and while it will have better FPS at 1440p isn't a particularly good choice between price and performance.
If you're looking into a GTX 980 it would be worth going all the way up for $100 more to the GTX 980ti, which is by far and away the current best single gaming card before you start looking at Titans.
