What graphic card will work?
Broplshelp
Commendable
Aug 29, 2016
28
Hello people,
My old graphic card nVidia 8800GT died while playing War Thunder yesterday, it always stays around 60-67 ° while playing games, I tried connecting different cables to it but PC always started with red lines on monitor.
I replaced it with another card i bought earlier XFX Radeon 5450 2GB which is working fine but was having trouble loading some sites until i installed latest driver.
I want to buy another card because AMD card is very old and cant run war thunder but I don't know which card will work with my PC.
PC details
Operating System
Windows 7 Ultimate 64-bit SP1
CPU
Intel Core 2 Extreme QX6850 @ 3.00GHz 69 °C
Kentsfield 65nm Technology
RAM
6.00GB Single-Channel DDR2 @ 333MHz (5-5-5-15)
Motherboard
Dell Inc 0PP150 (Socket 775) 72 °C
Graphics
Generic Non-PnP Monitor (1280x1024@60Hz)
1024MB ATI Radeon HD 5400 Series (XFX Pine Group) 49 °C
Storage
232GB Western Digital WDC WD25 00AAJS-75B4A SCSI Disk Device (SATA) 39 °C
Optical Drives
HL-DT-ST DVDRWBD GBC-H20N SCSI CdRom Device
DTSOFT Virtual CdRom Device
HL-DT-ST DVD+-RW GSA-H73N SCSI CdRom Device
Audio
Realtek High Definition Audio
Thank you guys for replying fas liek bugaty.
Had to take open CPU and take a look at PSU
Do you think this can handle GTX 950?
It's not about the wattage ceiling. It's about your PSU having 6pin PCI power connector. 950 requires one 6pin to operate.
However, at this level of output, putting actual quality aside, it gotta have at least one.
And if the behavior of 750Ti's retain still on the 950, it should work fine. 750Ti are known to be so robust, it can still run on a crappy PSU as long as it's at least 350watts.
