Question what graphics card is best for running warzone cod on a dell T1700
Joshua Alves
37
what graphics card is good for running warzone cod on a dell T1700 workstation i just got this computer btw is it possible or it isnt
What is the make and model of the PSU in that prebuilt? Regardless of what PSU you have in that prebuilt, you can't drop in an aftermarket GPU due to powersupply(make and model) restrictions and the proprietary nature of the motherboard. It doesn't matter how long it's been in your hands, what matters is how long it's been used since it was made and released from the factory. That being said, you should look at another system. Even if you did manage to drop in a GPU, you couldn't escape running the game on the lowest settings at 720p, most likely.
will this one do
MSI Gaming GeForce GTX 1650 128-Bit HDMI/DP/DVI 4GB GDRR5 HDCP Support DirectX 12 VR Ready OC Low Profile Bracket Included Graphics Card (GTX 1650 4GT LP OC)
