what graphics card to buy, will it fit in my motherboard and do i need to upgrade psu?
JWildOnes
44
My pc specs:
CPU : Amd FX(tm) 6100 six-core preccessor 3.3 ghz
RAM : 8Gb
Graphics Card : AMD Radeon 6670 2gb graphics card
PSU : Win power+plus 550w
Motherboard: gigabyte 78lmt s2p
I want to upgrade my graphics card to a decent good one that would be able to run bf4 smoothly, i was going to go for a gigabyte gtx 760 4gb or a gigabyte gtx 760 2gb:
4GB: http://www.amazon.com/Gigabyte-GTX760-GDDR5-4GB-Graphics-GV-N760OC-4GD/dp/B00EAMQMUG/ref=sr_1_2?ie=UTF8&qid=1387556203&sr=8-2&keywords=gigabyte+gtx+760
2GB: http://www.amazon.com/Gigabyte-GDDR5-2GB-WINDFORCE-GV-N760OC-2GD-REV2-0/dp/B00DGM8B6O/ref=sr_1_1?ie=UTF8&qid=1387556298&sr=8-1&keywords=gigabyte+gtx+760
Which one is better to get for gaming, do i have to upgrade my psu and will it fit in motherboard.
Need reply asap please
get a 760 2gb, 4gb is overkill. the psu is decent. you might not see the performance you want to go for because of your cpu. it is going to seriously hold back your whole system in games
not needed. the 760 considered not fast enough to utilze the full 4gb. the only way 4gb is useful is with a multi monitor(higher overal resolution) configuration. but then again a 760 is not powerfull enough
