What graphics card would be best for my mini itx build?
bcmmbc122333
20
I'm currently planning a mini itx build, with my focus being great performance with as little sound as possible. Here is the build I currently have in pcpartpicker https://pcpartpicker.com/list/NVKN9W. I feel like everything I have would be great, and would be very quiet, except my graphics card. I feel like the blower card is going to be loud but the fan style is going to be suffocated by the power supply. I specifically want an EVGA 1070 (not a hybrid) but I don't know which would be best for acoustics while still having low temps. preferably a card without rgb as well, but that's the least of my concerns.
here is a list of all the models to compare and contrast with. http://www.tomshardware.com/forum/id-3047729/nvidia-geforce-gtx-1000-series-megathread-faq-resources.html#17902599
i did not see any card that was obviously better than the others. as i read reviews i noted that there was rarely a difference of 3-4 degrees between the cards aside from the FE card with it's blower style which was loud n hot everytime.
the "mini" cards out for 1070 are a few degrees hotter due to the smaller heatsink and fan set-up. so the obvious choice of a short card brings some extra heat n noise by a few degrees. but this won't be enough to bring the system down. for instance the Zotac mini was whisper quiet with default fan curve and maxed about 70...
the "mini" cards out for 1070 are a few degrees hotter due to the smaller heatsink and fan set-up. so the obvious choice of a short card brings some extra heat n noise by a few degrees. but this won't be enough to bring the system down. for instance the Zotac mini was whisper quiet with default fan curve and maxed about 70 degrees with a small overclock on it. keep it at out of the box speeds and that will drop closer to 65 which is not bad for the power it brings to the system.
