Hi there,
Im planning to build a pc with these specs:
CPU: AMD Ryzen 3 1200 (I may oc to about 3.8 Ghz)
MOBO: Asrock AB350M-HDV
RAM: Crucial DDR4 Ballistix Sport 1x8GB 2400 CL16
GPU: GTX 1050 ti
Case: MS-Tech CA-0335
HDD: Western Digital Blue WD10EZEX 1TB
WIFI card:?
Because of my low budget I decided to chose a gtx 1050 ti, but don't know which version I should pick, was looking at the Gigabyte GeForce GTX 1050 TI 4GB OC and the MSI GTX 1050 TI AERO ITX 4G OC.
I'm also looking for a good wifi card for my system, I have both a 2.4 Ghz and a 5 Ghz network and would like to know which card I should pick.
GPU: GTX 1050 ti
WIFI card:?
