What happen when CPU Temperature Exceed Max Temp ?
officialexpert
318
Hello all,
I have AMD (X64)Athlon II X2 270 3.40 Ghz..Max Temp = 74 degree Celsius.
I want to know What happen if CPU Exceed Max temp ? Also want to know how to set alarm as well as Auto Shut down at 70 C? Also want to know that will be Immediate turn off like power cut or Stably Turn off like a Shut Down?
Does any harm to processor? Can I start PC after few mins or Shall I let the CPU cool by giving some time just say like 1-2 hours ?
I do check my CPU Temperature via HWMonitor.Will you recommend me this Software or Will you pick some other to check CPU Temperature?
