What happens if I put a non-PWM fan on a PWM header and set the BIOS to PWM?
Joshua D
58
Just wondering. I had a fan RPM display erratically earlier after setting it to PWM controlled in BIOS. Then I remembered it was a 3 pin fan....
No harm. Just poor to non existent speed control. PWM (pulse width modulation) controls speed by varying the DC pulses at the full +12v. But it only does that with the presence of the 4th wire. I suspect the 3-pin fan was running at full speed all the time.
DC control varies the speed by varying the voltage from +12V to +5V.
MERGED QUESTION
Question from Joshua D : "Bad Motherboard? Fan question..."
You had your answer here - http://www.tomshardware.com/answers/id-3652456/put-pwm-fan-pwm-header-set-bios-pwm.html
Normal behavior.
I don't know if I'm just not understanding it... (and, seriously, I appreciate any help), but if my fans are 3 pin non-pwm, and they are on 4 pin headers, how does that make the RPM display in the BIOS show the RPMs going from 1350, 1347, N/A, 1360, N/A, etc.? Isn't the 3rd wire the tach one? I'm not worried if it's some BIOS bugginess or something like that. It's just a new mobo, and I want to be sure nothing's wrong before the return period is over from the dealer.
