F flashvent Commendable Apr 27, 2016 49 0 1,530 May 7, 2016 #1 Ok so my internet is being crap and i have a Wireless network adapter what happens if you plug an ethernet cable into a computer if it already has Wireless Network Adapter?
rgd1101 Don't Moderator Nov 7, 2011 74,713 4,200 176,290 May 7, 2016 Solution #2 it will either use the Ethernet or the wireless, not both. Upvote 0 Downvote Solution
C CustomBulids Distinguished May 7, 2016 93 0 18,660 May 7, 2016 #3 Just disable the wireless adapter and use Ethernet Upvote 0 Downvote
M Mr_Slimon Commendable May 8, 2016 2 0 1,520 May 8, 2016 #4 Normally it will just use only one - in most cases the Ethernet as it should be faster but there is some programs that can use both at the same time ---} Combining Both Speeds i believe (Dispatch) is one of them - it is from the company that made (Connectify) the problem it's quite expensive - but you might need it if you want better speeds ---Update now it's called Speedify here is the link for Website http://speedify.com/ Upvote 0 Downvote
