What happens if you set ink volume max and dry time minnimum?
1zacster
221
I'm just wondering what would happen in an injet printer. Is there some sort of heat mechanism and if used does it warp the paper more? other things like that.
i have never heard of a heat mechanism in common inkjet printers. my guess is that the dry time is the time the printer waits before printing out another sheet. if you pull the sheets out as they are printed and lay them aside i do not see why it would matter. if you did not pull the sheets out then you might get smudging or bleeding from sheet to sheet contact.
