What Hybrid-Cooling/AIO GPU to get?
Sven__
30
Hey guys, I am pretty lost right now. I am trying to get a 1080 TI that has hybrid cooling. There are some products, but I really don't know which one I should get.
I was thinking this one from MSI or this one from EVGA. I am trying to stay within the $800-$850 range so if you have any other suggestions I would greatly appreciate it! I am pretty "noob" to high end graphics cards. Also, here's my build so far if you are concerned.
Thank you so much for any suggestions. Greatly appreciated!! :)
Oh yeah a quick edit, I really want the one with the best performance and overclocking or whatever. Thanks
My suggestions for your build:
1. GTX1080ti with a factory overclock is as good as you are going to get.
If you look at the boost clocks, there is not much to really distinguish one from the other.
I think I would pick a simple evga FTW3
https://www.newegg.com/Product/Product.aspx?Item=N82E16814487338
2. For a top end build, the 6 core i7-8700K costs about the same. Problem is finding one.
3. A noctua NH-D15s will be quieter, cool equally well, be easier to install and will not leak ever.
4. Pick a tier 1 or 2 psu from a list such as this:
http://www.tomshardware.com/forum/id-2547993/psu-tier-list.html
I like Seasonic.
Her is a top reviewed Seasonic 750w for less:
https://www.newegg.com/Product/Product.aspx?Item=N82E16817151187
Well, I am going Water cooled for 2 reasons.
First reason: My room is extremely hot, maybe around 79-81F (or for the rest of the world 26c-28c) so I really want to keep my cards cool.
Second reason: I want to overclock my GPU and CPU so I want to keep OPTIMAL temps.
Thanks for the suggestions, but I feel air is not the way to go :/
Thank you!
