Question What is a good budget or a good collation of parts for around 800-900USD?
Aug 14, 2019
16
I am a first timer for pc building and I was thinking of having a 800-900USD build. My parts would have consisted of :
-Ryzen 5 3600
-B450/X470/X570 motherboard
-16GB 3200-3600GHz ram
-256-512gb m.2 ssd
-1-2TB hdd
-Nvidia GTX1660Ti/2060 Super
-650W PSU
-Any RGB case
-Windows 10 Home OS
If you think there could be any changes or a more suitable budget and you could tell me that would be great! Thnx!😁
LordVile
1,494
58
5,490
48
-Ryzen 5 3600
-256-512gb m.2 ssd
-1-2TB hdd
-650W PSU
-Any RGB case
-Windows 10 Home OS
What do you mean by RGB Case?
LordVile
1,494
58
5,490
48
Can edit it but this seems pretty solid:
PCPartPicker Part List: https://pcpartpicker.com/list/jnTPbX
CPU: AMD Ryzen 5 2600 3.4 GHz 6-Core Processor ($133.00 @ Amazon)
Motherboard: ASRock B450M Steel Legend Micro ATX AM4 Motherboard ($89.98 @ OutletPC)
Memory: Corsair Vengeance RGB Pro 16 GB (2 x 8 GB) DDR4-3000 Memory ($89.99 @ Newegg)
Storage: Kingston A400 240 GB M.2-2280 Solid State Drive ($30.49 @ Amazon)
Storage: Western Digital Caviar Blue 1 TB 3.5" 7200RPM Internal Hard Drive ($44.48 @ Amazon)
Video Card: XFX Radeon RX 5700 XT 8 GB Video Card ($399.99 @ Best Buy)
Case: Cooler Master MasterBox Lite 5 RGB ATX Mid Tower Case ($63.98 @ Newegg)
Power Supply: SeaSonic S12III 650 W 80+ Bronze Certified ATX Power Supply ($58.99 @ Amazon)
Total: $910.90
Generated by PCPartPicker 2019-08-14 06:36 EDT-0400
LordVile
1,494
58
5,490
48
Ummm... i dont really know i need suggestions because im a first timer.
I see. You can drop to a R5 2600 rather than a 3600. It saves you around 60 in the CPU and expands the motherboards you can use to the cheaper end. However you may need better RAM than the one I listed, because I have a set of that RAM and have nothing but issues until I swapped it.
can I ask what you’ll be doing on this and if it’s gaming at what resolution and what is your monitors refresh rate?
Aug 14, 2019
16
Ok thnx. I will be mostly gaming and working on this pc . It will be at 1080p. I dont know about the refresh rate though as i havent bought the monitor.
LordVile
1,494
58
5,490
48
1080p is fine I’ll just edit the parts list for that. What type of work?
PCPartPicker Part List: https://pcpartpicker.com/list/PRBTvn
Memory: Corsair Dominator Platinum RGB 16 GB (2 x 8 GB) DDR4-3200 Memory ($129.99 @ Amazon)
Video Card: ASRock Radeon RX 5700 8 GB Video Card ($329.99 @ Newegg)
Total: $880.90
Generated by PCPartPicker 2019-08-14 06:57 EDT-0400
Reactions: BRUV
LordVile
1,494
58
5,490
48
Im a student so projects and maybe some other work for my parents? And what ram did you originally used i checked your profile and couldnt find anything except replies to others.
It’s in my Bio I think?
I used Vengence Pro RGB 3000 but kept getting BSODs on it with memory management errors. Switched to dominator plat and had no issue since
Aug 14, 2019
16
Total: $880.90
5700 vs. 2060 Super which is btr
LordVile
1,494
58
5,490
48
Down to price really. The 2060 super is a little faster but you’re only on 1080p and it’s $100 more expensive. It’s not $100 better if you get what I mean. Plus you’re paying the RTX tax which the 2060 Super really can’t do anyway.
I’m a fan of last gen hardware I bought a Vega 56 Strix for £260 but the deals over there aren’t as good you need a good cooler for Vega and it’s over the price of the better 5700 to get a good cooler.
Aug 14, 2019
16
Ok thnx. What about the 1660Ti?
Aug 14, 2019
16
That’s actually pretty good. Would bump your budget to over a grand but from what I know the only thing that outright spanks the 1080Ti is the 2080Ti which costs over a grand or is a Titan that costs over 2 grand.
Ok i am actually from Singapore and there is a place which sells new parts very cheap so it could fit into my budget.
