Hello this is my first thread. I need your help to decide which case best suits for the system that I will build. I would like to have a good air flow because I don't like my system over heating, and I don't plan on adding a GPU and HDD anymore. These are the specs:
Motherboard: ASUS M5A78L-M LX PLUS Motherboard
CPU: AMD FX-6300 will overclock to 4.2ghz
CPU COOLER: COOLER MASTER HYPER 212X evo
GPU: R9 270X 2G OC
RAM: KINGSTON HYPERX BLU 4GB 1600MHZ
HDD: WD 1TB blue
PSU: AEROCOOL STRIKE-X 600W 80+ BRONZE
I am thinking which of these 3 cases will be good:
Aerocool rs-9
Antec three hundred
Antec one
It will be good if you suggest me a case too. If possible only cases from here http://pcx.com.ph/components/chassis.html or the one I can buy in the Philippines. Thanks.
GPU: R9 270X 2G OC
HDD: WD 1TB blue
Aerocool rs-9
Antec three hundred
Antec one
