[SOLVED] What is a good iCue cooling settings for iCue H115i XT RGB PRO when running a Ryzen 7 5800x CPU?
mac187
37
Hi!
I have a Ryzen 7 5800x CPU and a iCue H115i XT RGB PRO cooler.
I want to try make a good fan curve for keep good cooling for my CPU.
I used to play most games, but my wife use it most for work and browsing.
So i want a good mix of quit and good cooling when play games or make more hard work on my pc.
I have now these settings. Is it good or should I change something?
View: https://imgur.com/a/1sWYT6C
What do you think?
Thank you for help!
It's a place to start but ultimately it all will depend on what the temps are showing for what task the cpu is doing.
Did you try Balanced mode on the fans?
Setting a custom curve I found took some getting use to.
I use hwinfo64 watching the tcl-tdie reading and Ryzen Master for temps during various workloads, idle, browsing, office work, gaming, or any other cpu intense programs vs what your hearing will allow.
There maybe some trade offs in what you want vs what you have to get use to.
From the pic something seems odd to me.
You have it set to custom but yet your fans are set on default.
