stl522013 Reputable Mar 15, 2015 1,076 0 5,360 Jan 18, 2016 #1 I am making a build for a friend. What is a good purple case fan for a good price? Thanks.
COLGeek Cybernaut Moderator Apr 6, 2009 59,642 5,363 184,340 Jan 18, 2016 #2 What size fan are you looking for? Try here: http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=100007998%208000&IsNodeId=1&page=1&bop=And&ActiveSearchResult=True&SrchInDesc=purple&PageSize=30 I prefer the Corsair fans over the Xigmateks, both are decent though. Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,818 1,871 159,590 Jan 18, 2016 #3 I have the Corsair AF Purple LED's and they look real nice. Upvote 0 Downvote
stl522013 Reputable Mar 15, 2015 1,076 0 5,360 Jan 18, 2016 #4 COLGeek : What size fan are you looking for? Try here: http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=100007998%208000&IsNodeId=1&page=1&bop=And&ActiveSearchResult=True&SrchInDesc=purple&PageSize=30 I prefer the Corsair fans over the Xigmateks, both are decent though. 120mm. Upvote 0 Downvote
COLGeek Cybernaut Moderator Apr 6, 2009 59,642 5,363 184,340 Jan 18, 2016 #5 There are a couple 120mm options on the link sent earlier.Up to your friend's budget. Both SR-71 and I agree that Corsairs are the way to go. Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,818 1,871 159,590 Jan 18, 2016 #6 http://www.newegg.com/Product/Product.aspx?Item=N82E16835181047&ignorebbr=1 Upvote 0 Downvote
stl522013 Reputable Mar 15, 2015 1,076 0 5,360 Jan 18, 2016 #7 Thanks. Since three fans are so expensive he may want RBG fans. Are the Thermaltake Riing 12 pack of thee RGB fans with the controller any good? http://www.newegg.com/Product/Product.aspx?Item=N82E16835106355 Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,818 1,871 159,590 Jan 18, 2016 #8 The Riing are decent fans I have the 140mm whites., but never used the fan controller version. Upvote 0 Downvote
stl522013 Reputable Mar 15, 2015 1,076 0 5,360 Jan 18, 2016 #9 PCPartPicker part list / Price breakdown by merchant CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor ($174.89 @ OutletPC) Motherboard: ASRock H97M PRO4 Micro ATX LGA1150 Motherboard ($62.98 @ Newegg) Memory: G.Skill Sniper Series 8GB (2 x 4GB) DDR3-1866 Memory ($44.99 @ Newegg) Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($49.98 @ OutletPC) Video Card: MSI Radeon R9 380 4GB Video Card ($189.99 @ Newegg) Case: NZXT Source 220 ATX Mid Tower Case ($49.99 @ NZXT) Power Supply: EVGA 750W 80+ Bronze Certified Semi-Modular ATX Power Supply ($44.99 @ NCIX US) Operating System: Microsoft Windows 10 Home OEM (64-bit) ($87.95 @ OutletPC) Case Fan: Corsair Air Series AF120 Purple 52.2 CFM 120mm Fan ($12.59 @ OutletPC) Case Fan: Corsair Air Series AF120 Purple 52.2 CFM 120mm Fan ($12.59 @ OutletPC) Case Fan: Corsair Air Series AF120 Purple 52.2 CFM 120mm Fan ($12.59 @ OutletPC) Total: $743.53 Prices include shipping, taxes, and discounts when available Generated by PCPartPicker 2016-01-18 16:39 EST-0500 This is the full build. His budget was $700 but he said he would spend more for the purple fans. Upvote 0 Downvote
COLGeek Cybernaut Moderator Apr 6, 2009 59,642 5,363 184,340 Jan 18, 2016 #10 Nice build. Upvote 0 Downvote
stl522013 Reputable Mar 15, 2015 1,076 0 5,360 Jan 18, 2016 #11 COLGeek : Nice build. Anything you would change while still staying in budget? Upvote 0 Downvote
COLGeek Cybernaut Moderator Apr 6, 2009 59,642 5,363 184,340 Jan 18, 2016 #12 stl522013 : COLGeek : Nice build. Anything you would change while still staying in budget? Not really, no. This is a solid build. Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,818 1,871 159,590 Jan 18, 2016 #13 I agree very solid build , great choices. Upvote 0 Downvote
