[SOLVED] What is a good speed for an nvme?
Ibraimo
124
Im planing on buying an nvme sdd but i like to know first, what is a good speed im seeing some like 2500mb write up.... soo tell what speed is good?...
Buy a brand name NVME 3.0 drive and you'll typically see between 2500 and 3500mb read and slightly slower write speeds depending on controller type and cache size differences.
There's no reason to buy an NVME 4 drive unless you do a lot of large file transfers as SATA SSDs, NVME 3, and NVME 4 drives all provide a similar gaming and Windows experience for the end user.
Brand wise look for samsung/wd/crucial you won't go too far wrong.
Don't spend extra for a pcie4 ssd if you have a pcie3 slot.
Perf wise don't be surprised if you see very little if any diff between a 2.5 ssd and a pcie ssd when running your stuff.
Any NVME over 480 Mbps is good but an NVME SSD should get at least 1500 Mbps imo. Also what you should be looking at is cache memory. Some have those. Some doesn't. Cache will make night and day difference
