What is a power fan connector?
Not sure what part of "works the same as any other fan header port" needs more clarification here. If you have a fan controller that needs a 3-pins fan header connection for whatever reason, then the power fan should be just as good as any other standard 3/4-pins fan header.
The power fan header (PWR_FAN) allows for monitoring the RPM of the PSU fan if the PSU has the appropriate wire to plug in to it, otherwise you just ignore it.
It's entirely optional anyway, even if the PSU does have the appropriate wire, It's not necessary to connect anything to that header to have a working system.
Hmm, Thanks. So it is not related to CPU fan. Like if i put a 3-pin speed controller there. It wont let monitor my CPU fan?
Ok, thanks. It is not related to any other PC fan then like CPU fan or just system fan?
Ouh cool, thank you! But can i but a fan controller there?
