[SOLVED] What is a serial ata connection for?
BPR96
84
I am using the NX400 case by Antec, which has RBG at the front of the case, I have noticed there is a spare connector which has “serial ata” on it.
where does the plug in to? I have read that it maybe goes into storage devices, but I already have my SSD hooked up with a SATA power/data cables.
many idea why it’s for? Thank you
its not for your hdd/ssd.
it'll be for one of the front ports on the case. could be usb ports or possible other port. is there an eSATA connection on the front? that would use a sata port.
but leaving it unconnected won't hurt anything. just whatever wants the connection won't work. that would be a good way to test what it is for
Latest posts
