Looking at this document, it seems your desktop has only old-style IDE disk interface (40-pin ribbon cable), so your search for replacement drive should include "IDE/PATA DVD-RW drive". If the original one is standard full-heghgh (about one inch tall), then something like this should fit
You can use any 5.25" CD/DVD drive in that case, as long as it is an older IDE model. I don't recall that model having any SATA ports on the motherboard.
you're right about it being ide/ 40 pin ribbon cable, but the product in the link's measurements may be about an inch too long I have to to home and check. But thanks for the info and link.
Do you think something like this would work? http://
Or could I just get a sata converter with the right size dvd rw device as scout_03 mentioned? link here http://
... Do you think something like this would work? http://
Any drive which has IDE/PATA interface would work. SATA-IDE converters could work, too, but I don't know whether you will be able to boot off such a drive.
