As usual I agree with the other skeleton faced guy, tho do keep in mind that prolimatech tech support will tell you they recommend against any fans over 1200 rpm. I have Enermax testing these for me in a ganged configuration to see if the MoBo's COU header will control ganged set in push pull.
http://www.frozencpu.com/products/7489/fan-437/Enermax_Cluster_120mm_x_25mm_LED_PWM_Fan_w_Twister_Bearing_Technology_-_White_UC-CL12.html
I'd suggest one of these for RAM
http://www.newegg.com/Product/Productcompare.aspx?Submit=ENE&N=2010170147%2050001550%201052345114%201052429371&bop=And&ActiveSearchResult=True&CompareItemList=N82E16820227501%2CN82E16820227365
I don't think you will see any benefit from the extra 6 GB of RAM
I'd suggest the Antec CP-850 PSU over the Corsair TX.....it's designed specifically for the 1200 case and electrically is comparable to Corsair's top of the line HX-850. See:
http://www.silentpcreview.com/Recommended_PSUs
http://www.silentpcreview.com/Antec_CP-850
If you haven't bought those HD's yet, I'd be willing to bet that a single WD Black 2 TB model (or Spinpoint F3) would outperform the 640's in RAID in gaming benchmarks. Note only the 2 TB WD has the 500 GB platters like all the F3 models.
Note: I just finished a build w/ my son in the Antec 1200 case w/ the megahalems.....tips....
1. As per Prolimatech TS, install with HS fans blowing to rear (yeah i know, logic says up but TS say they have tested better the other way.
2. If you use hi end RAM in a 12 GB configuration, check w/ manufacturer about fi. For example, I used Mushkin CAS 6 memory with the Ascent coolers (998692). Mushkin recommends against using these and recommends the 998691 models (w/o the Ascent coolers) in 12 GB configurations to provide adequate air flow between the modules.
3. If you buy the 'optional" two fans for the 1200, you have to mod the case window mounted one. Simply done w/ a dremel tool. The only way i can describe the mod is for you to think if the fan as a salami sandwich.....round fan housing (salami) sandwiched between 2 square mounting plates (bread). Thinking now of opening the sandwich and looking at just one side, you'll see 4 little triangles of bread, one at each corner, that aren't covered by the salami.....trim one corner off (top one when mounted in case) just one of the pieces of bread (exhaust side facing CPU) and you'll fit fine. Took about 90 seconds to do the mod.
