2x4GB allows use of dual channel which can up the performance of DRAM by up to 10-15%, I favor GSkill sticks in 2x4GB in an instance like this, once up and running can try adding the old for a bonus or sell the old DRAM
That's laptop DRAM and you have a desktop computer, depending on what you do 1333 or 1600 DRAM should be fine, your mobo can handle 32GB, 8GB is generally the entry level these days,what all do you do w/ your rig?
