I have noticed that most people lean toward the P5W DH Deluxe or the P5WD2-E Premium. I suppose for the duel x16 slots. I was thinking about the P5B deluxe WiFi, since reading the ASUS forums it seemed to have the LEAST amout of problems. Yet I realize that this may simply be because it is soo new and/or the nubs buying it??
Any thoughts Ideas as to which (minimum 8-phase pwr reg) mobo is best? Especially you Wussy, you seem to know alot about hardware. <3. Im just an ASUS fan that has heard alot about a gigabye mobo that has 12-phase power regulation and is highly OC'able. Looking for enlightenment.
I want opinions on a solid base (motherboard) for my new system and of course will need compatable memory advice since I hear way to many sob stories about peeps buying sticks that dont work on the mobo they bought. And want it cheap. Looking at 1 GB(2x512) corsairs for around $100
Of course Im looking at 775 so that when core Duo is cheaper I can drop one in. Have had lengthy discussion regarding the possibility of OC'ing a D 805 with a CNPS9500, but now conceed I may be better off starting with a cheaper(yet Better) 120mm HS and a Pentium D 915 for its 65nm core and 2 x 2Mb L2. May still go with the 9500 cause its smaller and looks kewl. The blue matches the rest of my system.
Thanks in advance.
Thanks in advance.
. remember I never actually said I was going to get that for sure. If I go with a Ninja for $38 at Xoxide.com I can use extra money for a D 915?? its only $137 at newegg.
