Oh another thing, the ryzen 7 and rtx 570 should be able to run the newest games right? on low settings at least.
So im buying an already made pc and i have 2 choicesThat's a subjective question. First of all, what's your BUDGET ? How much are you willing to spend on a PC ? Do you plan to game on 1080p, 2K, or 4K resolution Monitors ?? Are you a HARDCORE gamer, or casual/light ?
You need to first specify your needs, then only we can recommend any GPU/MOBO.
lc power 500 wGo for the RX 570 GPU. It's much faster than the GTX 1050 Ti as well. For 1080p, the RX 570 is a decent choice. This might be a slightly old news article, but just give it a read:
https://www.techspot.com/review/1777-geforce-1050ti-vs-radeon-570/
What about the Power supply unit ? Do have one with you right now ?
Snippet taken from the above article:
On average the Radeon RX 570 was an astounding 43% faster than the GeForce GTX 1050 Ti at 1080p. Clearly where AMD has not been able to deliver on the high-end, they are making up on budget and mainstream GPU solutions priced below $300.
The biggest AMD wins in this comparison were seen on DX12 titles supporting async compute, that said AMD did sponsor Strange Brigade and Sniper Elite 4. Meanwhile, the smallest wins were seen in Grand Theft Auto V and Assassin’s Creed Odyssey. Neither title has proven to be AMD friendly in the past, but even so the RX 570 as able to get up over the GTX 1050 Ti here.
Without a doubt, the RX 570 is a faster GPU and now that it's price matched to the 1050 Ti, or is generally a little cheaper, it’s the obvious value choice for most gamers. We will note that the RX 570’s power consumption is significantly higher that the GeForce, but you’re looking at well under 300 watts for total system consumption. So while it is extreme relative to the 1050 Ti, it’s not outrageous overall.
lc power 500 w
My plan is to keep the pc like that for a year and after that to upgrade the motherboard and the psu. what do you think about that?
I will be getting a 240gb ssd. Now i only have those options because buying parts in my country can be like 200% pricier than buying them in lets say usa. So because of that i have to buy an already made pc. Now i was also thinking about the second choice cause of the gpu, and another thing is that i dont use the overclock so it doesnt matter to me that i cant overclock it.I will upgrade the motherboard later on but i want to use this as my starting machine lets say. It should run most of the titles on normal at least from what ive seen so thats pretty much all i need.Thank you for all of the help but yeah i think the second option is far better than the first one. Thank you for your time again!Okay here's the deal. There's no such thing called a stronger motherboard. However, there are categories of it. The higher you go, you get features like overclocking, more fan/SATA/PICe/M.2 slots, better slot positioning and quality, better heatsinks for the VRMs and chipset, more RAM channels, better audio etc.
So, you have 2 options, the A320M and B350M. I would not suggest any of those but you have no choice but these 2 according to you. So, A320M is the barebone AM4 mobo. You can't overclock anything with it, and you just have 2 channels for RAM. So let's say you want to add more memory in the future, well, you wouldn't be able to, assuming the B350M is quad-channel. If it's dual channel as well, well, only difference would be, you won't be able to overclock your CPU.
So if the 8GB RAM is just a single stick, you will have one channel free on the A320M for future upgrades. And 3 channels free on the B350m, again, assuming it's quad.
But if you are the person who wouldn't upgrade at least in the near future, and won't overclock, the A320M package is the better choice, as you are getting a 500GB HDD and RX 570, which are better than the 320GB HDD and 1050 Ti respectively.
Now comes to PSU, well, both PSUs are terrible. But it's enough to power the both specs. However, I have doubts about the RX 570 and that PSU. Any way you can change the PSU to something at least 500W 80+ bronze of any brand ?
Last but not least, I would suggest that you get a SSD too. SATA ones are cheap. As 500/320GB are too small for 2019. So using the SSD, you can put the OS and your favorite game/software there for comfortable use. You can always buy a bigger hard drive internal or external later on.
I sure hope so, but hey if anything happens in the first 24 months i have the warranty or the assurance or however its called so yeah. I have a better one at home so if needed ill just change it(PSU). This is the first time im buying a pc so i wanted to get as much info as possible. Thank you for all your time and effort mates! Oh another thing, the ryzen 7 and rtx 570 should be able to run the newest games right? on low settings at least.Sure, the second one is the better choice. I just hope that monstrosity of a PSU doesn't die on you.
Haha rtx 570. Anyway, in 1080p, you will be able to play most modern games at ultra-high in 60fps. Except for some terribly optimized games like any Assassin's Creed game, Metro Exodus, where you will have to tinker with the custom settings a bit to get 60 fps.I sure hope so, but hey if anything happens in the first 24 months i have the warranty or the assurance or however its called so yeah. I have a better one at home so if needed ill just change it(PSU). This is the first time im buying a pc so i wanted to get as much info as possible. Thank you for all your time and effort mates! Oh another thing, the ryzen 7 and rtx 570 should be able to run the newest games right? on low settings at least.
Thank you! Thats all i needed. You guys were really helpful and i wish you the best of luck!YES....You have a pretty decent CPU, and even the RX 570 is a capable card for 1080p. No need to lower all the game settings though, except for some graphic demanding PC titles. .
