P papichups12 Prominent Oct 3, 2017 6 0 510 Oct 3, 2017 #1 So that's my question. A GPU will be better if it had 7,008 MHz or 1,290 MHz?
Solution 13thmonkey Oct 3, 2017 papichups12 : So that's my question. A GPU will be better if it had 7,008 MHz or 1,290 MHz? more, however 1290 DDR5 is also known as 1290*5=6450 which should be compared to the 7008 value.
vapour Champion Aug 28, 2017 12,397 98 57,540 Oct 3, 2017 #2 The more, the merrier. But you also need to consider cooling/noise level. Upvote 1 Downvote
feelinfroggy777 Glorious Dec 13, 2016 5,722 135 45,990 Oct 3, 2017 #3 You want it higher without crashes or artifacts. But don't expect miracles by increasing memory clock speed. You will be a bump in performance, but not nearly as much as the GPU clock speed. Upvote 1 Downvote
13thmonkey Titan Jan 10, 2006 24,790 350 75,790 Oct 3, 2017 Solution #4 papichups12 : So that's my question. A GPU will be better if it had 7,008 MHz or 1,290 MHz? more, however 1290 DDR5 is also known as 1290*5=6450 which should be compared to the 7008 value. Upvote 1 Downvote Solution
rolli59 Titan Oct 27, 2007 47,803 285 130,890 Oct 3, 2017 #5 papichups12 : So that's my question. A GPU will be better if it had 7,008 MHz or 1,290 MHz? The higher the better on the same GPU. Performance can not be determined between two different GPU's on memory clock alone! Upvote 1 Downvote
P papichups12 Prominent Oct 3, 2017 6 0 510 Oct 3, 2017 #6 Thank you guys for your answers! I appreciate them!!!. Sad that I can't give you all "Pick as the solution" Upvote 0 Downvote
