Check out the 49in Wally World Sceptre 4k. So far it's been the best gaming experience that I've had with a tv. The picture isn't as good as the Samsung. I have heard the lowest input lag is the LG OLEDs. There was an article about the different model tvs and their input lags but I can't find it right now. Avoid the Sharp, that was the worst lag I've seen on a tv. I have heard the vizio are decent for a good experience but they didn't have the one I wanted at the store when I bought my Sammy (the vizio was my first choice). If you're really sensitive to input lag, a monitor is the way to go, it sucks, but the tvs just aren't designed around a fast experience, think about the games that excel on PS4 or XBOne. People just wouldn't be competitive at say CS:GO, just not fast enough response times. TVs are made for the best picture, so the processors in side are usually better than a monitor at image processing but they also take longer. You would think that if you're running native 4k or 1080 or 720 there shouldn't be any need for image processing off a computer, but they're not designed for that, they're designed to make BLU Ray and DVD and the web stuff look good, so it's almost always compressed to hell and upscaled for the tv to use and the tv will try to clean the picture as best it can.
