Hello
got XFX RX 480 8GB Black Editions, it got switch button for performance or steatlh (i dont have enough information which side to A or B)
first come bios switch in on the right side, testing on Assassin's Creed Odyssey set ultra got 45-50 fps playing on 1920x1080 and see metric overlay in radeon software, and got result
Temperature 90 degree 'ish
Fan like 2000-2500 rpm
change my bios switch to left side and testing same game with same setting, got
Temperature 70 degree 'ish
Fan blowing like 3500 - 4000 rpm
(so i'm guessing left side switch is performance mode)
but i'm curious what is maximum rpm for a gpu? Because 4K rpm is very loud and i'm worried it will break/bounce at some point, i dont know how to change rpm to percentage in radeon software setting, i think it's not there because i'm looking here and there and found nothing.
or, should i use stealth mode, fan is silent or stealth, but it sure hot as hell because i can feel the heat touch my arm (i'm putting my case in the right side of monitor where my hand near it because using mouse. Is it safe to using gpu at 90 degree 'ish? because some times it hit 94
