C carlosmarin Honorable Nov 27, 2012 1 0 10,510 Nov 27, 2012 #1 How do i check my LAN connection speed- is the same as the speedtest t I run from the internet ?
RealBeast Titan Moderator Sep 13, 2010 17,123 477 104,790 Nov 27, 2012 #2 Use LAN Speed Test: http://download.cnet.com/LAN-Speed-Test/3000-2085_4-10908738.html This program copies a small test file and measures the connection from device to device on your network. The Internet run test will only show you if you are getting the same Internet connection speeds but will not give you an actual LAN speed if it exceeds your Internet connection. Upvote 0 Downvote
