Antec 600 Case, Xigmatek 500W PSU, Asus P8Z68-V Pro Gen3, I5 2500K, 16GB 1600 Ram, Kingston S100 120GB SSD System Drive, Seagate 500G SATA 3 data drive, 2 monitors, Win7 P/64 SP1 B 7601
While operating , system will freeze or shut down. On reboot hangs. Go to BIOS V 0402 and SSD is missing from boot sequence. The first time I exited without save so as not to remove SSD from Boot.
This does not work. SSD must be again placed in boot sequence.
Is MB loosing track of SSD and changing boot info, or is SSD failing and MB does not detect and automatically remove from sequence (#1 and only system device). IS power supply failing and causing the problem. I add this option as I just put in Sapphire HD 6850 and problem surface soon after. Now VGA has been removed and back to on Chip Video and waiting for reoccurrence.
My boot is so fast that Samsung HD 2770 turns on after desktop appears. To run bios have to guess when to push Del. Only running IE and office at 1920X1080 so PSU should handle one 6850 and two monitors. Intend to update PSU to Sesonic Gold X650 when I can.l
How can I isolate the culprit. Does not seem to be heat related. System loafing and Antec Khuler H20 60 on CPU at 19C and MB at 22C . On standby overnight no problem, only while in use so far. Lucky not a business machine or this would be a major problem.
When I first installed SSD as ISRT cache I got little improvement in performance and people here told me to convert to boot drive. Did not think 120G was big enough for boot but the advice was right on.
Installed Win7/64 in 50G and updates and SP1 to 60G with normal performance applications on D: I still have 50% left for performance programs. Thanks for help rollie59 and RetiredChief.
