dumbleburn Reputable Aug 19, 2017 56 0 4,530 Dec 23, 2018 #1 So I just downloaded CPU-Z because I wanted to know if the RAM I have (8gb DDR3 HyperX Fury) is 1866MHz or 2133MHZ but I can't find that. It says that my NB Frequency is ~2700MHz , my DRAM Frequency is 933.6MHZ and my FSB😀RAM is 1:14.
Solution C C Calvin7 Dec 23, 2018 DRAM Frequency is 933.6MHZ Double Data Rate (DDR) means you would double the above figure to calculate your RAM speed.
dumbleburn Reputable Aug 19, 2017 56 0 4,530 Dec 23, 2018 #3 ThatVietGuy : 40 million ghz Sorry, just edited it lol Upvote 0 Downvote
C Calvin7 Titan Feb 19, 2013 11,722 336 76,490 Dec 23, 2018 Solution #4 DRAM Frequency is 933.6MHZ Double Data Rate (DDR) means you would double the above figure to calculate your RAM speed. Upvote 0 Downvote Solution
dumbleburn Reputable Aug 19, 2017 56 0 4,530 Dec 23, 2018 #5 Calvin7 : DRAM Frequency is 933.6MHZ Double Data Rate (DDR) means you would double the above figure to calculate your RAM speed. Ah, so that means my RAM is 1866MHz? Thanks Upvote 0 Downvote
