What is power requirements for AMD FX-8320?
(typical) System power draw should be around 275W or less. Any quality 350+ PSU should handle this just fine. Make sure it has the 6pin power plug the 550TI needs.
Summary
Operating System
Windows 7 Home Premium 64-bit SP1
CPU
Intel Pentium E5800 @ 3.20GHz 41 °C
Wolfdale 45nm Technology
RAM
6.00GB Dual-Channel DDR3 @ 398MHz (6-6-6-15)
Motherboard
Dell Inc. 018D1Y (CPU 1) 49 °C
Graphics
DELL ST2321L (1920x1080@60Hz)
1023MB NVIDIA GeForce GTX 550 Ti (EVGA) 39 °C
Storage
931GB Seagate ST31000528AS (SATA) 36 °C
Optical Drives
PLDS DVD+-RW DH-16ABS
Audio
NVIDIA High Definition Audio
Operating System
There :) Sorry for not responding
You'll have to take the side off the computer and look at the model number, brand, etc. Unless you can look it up online from where you bought it. (Amazon, newegg, etc all keep your purchase history.) I am running a 450W PSU in my computer, but there are other 450W PSUs I won't even let in my house, let alone my case.
Ok, this is very surprising I only have 300w.
