S seakay Reputable Mar 25, 2015 23 0 4,510 Jun 12, 2015 #1 Hello, Looking for a best overall value preferably for under $150, low power consumption GPU so I don't have to upgrade my PSU. Any suggestions?
Solution ThatVietGuy Jun 12, 2015 You have at minimum 375W which is good enough for the GTX 750ti - http://www.dell.com/content/products/productdetails.aspx/xpsdt_420 Otherwise, look on the PSU itself for a sticker/label that will tell you how many watts it puts out.
AznGOD Honorable Dec 31, 2013 406 0 10,960 Jun 12, 2015 #3 a gtx 750ti For around 300watt psu a r9 270 for around 400 watt psu Upvote 0 Downvote
cdabc123 Splendid Jun 9, 2015 3,638 2 25,715 Jun 12, 2015 #4 gtx 750ti its a great gpu and its not that expensive ether. I run one and it is amazing. Upvote 1 Downvote
S seakay Reputable Mar 25, 2015 23 0 4,510 Jun 12, 2015 #5 I have a factory build XPS 420. Not sure what the PSU is, how do I find out? Upvote 0 Downvote
ThatVietGuy Titan Nov 6, 2007 11,726 318 70,240 Jun 12, 2015 Solution #6 You have at minimum 375W which is good enough for the GTX 750ti - http://www.dell.com/content/products/productdetails.aspx/xpsdt_420 Otherwise, look on the PSU itself for a sticker/label that will tell you how many watts it puts out. Upvote 0 Downvote Solution
