What is the best gaming Graphic card to work with Gigabit 880 USB3 Motherboard? Is GTX 950 or GTX 750 will work better?
emadabd
Need the most compatable Gigabyte Gaming Graphic Card with 880USP3 Motherboard?
Is GTX 750 ti will work better or GTX 950/960 will work better?
Thank you
If your PSU has a 6pin connector for the Video card then the 950 is better, but it's actually a 960 with some features disabled and the recommendation is to spend a few $ more and get the 960. Without the 6 pin connector the 750Ti is as good as it gets. Buying a PSU if necessary gives a lot more options. You might look at Best Graphics card For The Money Chart.
