Question What is the best monitor for my AMD Ryzen 5 2600 and RX570 combo?
Nov 5, 2019
7
Hi guys! I just wanted to ask you guys on what monitor you could suggest for my new build. I want to play games like GTA V, Watchdogs.. My current monitor is 22' 1600x1050 60hz. I'm kinda afraid that if i push to 1920x1080 resolution, my GPU won't handle it. And also, should I stick to 60hz?
Thanks!
Build:
Processor : Amd Ryzen 5 2600
MOBO: MSI Mortar Max
Ram: 8gb x2 3200hmz
Nov 5, 2019
7
Thanks guys! So i should buy a monitor that is 1920x1080 60hz. Should i buy with a freesync feature or that would be unnecessary?
ohio_buckeye
976
229
11,390
28
If you are able to get one with freesync that is a nice feature as it is supposed to help with smoothing out games. Your RX 570 won't be capable, but if you get a good deal, you don't have to limit yourself to 60hz. You could go for 75hz it higher and then set the monitor back to a lower speed if needed. But it would give you that for whenever you eventually upgraded your gpu.
Reactions: xiaanliim
Latest posts
