What is the best nvidia control panel settings for quantum break???
If that doesn't work for you then you probably want to mention your current build (GPU, CPU, Memory, OS) information what setting you are using and what Fps your getting. Then what you trying to get or setting you want to use.
My PC:
INTEL CORE I5 3340,3.1GHz 6MB CACHE
GIGABYTE GEFORCE GTX 960 WINDFORCE 2X OC 2GB
KINGSTON HYPER X FURY BLUE 8GB 1600MHz
WINDOWS 10 PRO
BENQ GL2460
I get 50-60fps when i play on 1080p,medium texture,high volumetric light,and all the settings on the lowest
I'm trying to raise some settings and on 1080p and get the same fps
