[SOLVED] What is the best RTX 3060 Model as for cooling/$?
Amr Ibrahim
23
I don't get the wide variety of GPU's difference between different creators ( ASUS / GIGABYTE / MSI / ... )
I wanted to buy RTX 3060 but i was wondering which model has best cooling. Or at least on average, which creator has overall better cooling
The cooler you get on a 3060 will be appropriate to that particular card.
Some come factory overclocked and will have better coolers.
A GPU will target 80c. as a target temperature and perform as best it can at that point.
I would not worry much about coolers.
Instead, look at your case fresh air intake capabilities.
Any cooler, be it gpu or cpu needs a good source of fresh air to let it do it's job.
View: https://www.youtube.com/watch?v=vGZmK341Hrc
(Lower is better)
From the numbers, Asus strix
Reactions: Amr Ibrahim
Basically, the best 3060 is the one that you are able to buy. The variance in GPU availability from moment-to-moment is far larger than the variance in performance/cooling between an average 3060 and a higher-binned/more aggressively cooled 3060.
In other words, the GPU market right now is like being on the Titanic and wondering which lifeboat has the best rowers. Get in a lifeboat.
