what is the best water cooling kit for am3 socket
Well that depends, do you want something just for the cpu that you can not expand for a gpu in the future such as the Corsair H100i AIO or do you want something that you can expand for a gpu in the future.
If you are after something just for the cpu then I would suggest going down the corsair line such as the H100i:
http://www.amazon.co.uk/Corsair-CW-9060021-WW-Extreme-Performance-Liquid/dp/B00SV7IEJI/ref=sr_1_1?ie=UTF8&qid=1451277836&sr=8-1&keywords=corsair+i100
But if you want to be able to expand in the future then I would look around at the EK kits https://shop.ekwb.com/kits or have a look at some of the Alphacool kits like this...
But if you want to be able to expand in the future then I would look around at the EK kits https://shop.ekwb.com/kits or have a look at some of the Alphacool kits like this:
http://www.amazon.co.uk/Alphacool-NexXxoS-Cool-Answer/dp/B008LZNXF0/ref=sr_1_1?ie=UTF8&qid=1451278276&sr=8-1&keywords=alphacool+kits
It all depends on what type of loop you want and how much you are willing to spend all of them will be compatible with each other and should work on the AM3+ socket as there is no difference between AM3 and AM3+. Hope this helped a little, if you need any more help with this then just ask and il gladly help out :)
