Question What is the diff between CORSAIR - 4000D AIRFLOW and CORSAIR - 3000D AIRFLOW
4DY
Dec 10, 2023
24
What's the difference between
CORSAIR - 4000D AIRFLOW and​
CORSAIR - 3000D AIRFLOW​
Not quite good enough a comparison. If I am reading things correctly, the 3000D is slightly wider which means you have a little more room for water cooling radiators. IE they specifically call out that you can install a 280mm in the top of the 4000D if you use low profile memory.
The 4000D is also slightly taller.
Only major reason to pick between them that I can find.
Reactions: 4DY
