[SOLVED] What is the difference between asrock h410m-hdv and asrock h410m-hvs??
Here is the compare from ashrock site hdv vs hvs . The differences is at rear panel and at graphics,I orange so u notice em.
Rear panel I/O HVS :
1 x PS / 2 Mouse / Keyboard Port
  • 1 x D-Sub Port
  • 1 x HDMI Port
  • 4 x USB 2.0 Ports (Supports ESD Protection)
  • 2 x USB 3.2 Gen1 Ports (Supports ESD Protection)
  • 1 x RJ-45 LAN Port with LED (ACT / LINK LED and SPEED LED)
  • HD Audio Jacks: Line in / Front Speaker / Microphone
Rear panel I/O HDV:
  • 1 x PS / 2 Mouse / Keyboard Port
  • 1 x D-Sub Port
  • 1 x DVI-D Port
- 1 x HDMI Port <---------- here
  • 1 x RJ-45 LAN Port with LED (ACT / LINK LED...
  • 1 x D-Sub Port
  • 1 x HDMI Port
Rear panel I/O HDV:
  • 1 x D-Sub Port
  • 1 x DVI-D Port
Graphics HVS :
Hardware Accelerated Codecs: AVC / H.264, HEVC / H.265 8bit, HEVC / H.265 10bit, VP8, VP9 8bit, VP9 10bit, MPEG 2, MJPEG, VC-1**
  • Graphics, Media & Compute: Microsoft DirectX 12, OpenGL 4.5, Intel Built In Visuals, Intel Quick Sync Video, Hybrid / Switchable Graphics, OpenCL 2.1
  • Display & Content Security: Rec. 2020 (Wide Color Gamut), Microsoft PlayReady 3.0, Intel SGX Content Protection, UHD Blu-ray Disc
  • Dual graphics output: support HDMI and D-Sub ports by independent display controllers
  • Supports HDMI 1.4 with max. resolution up to 4K x 2K (4096x2160) @ 30Hz
  • Supports D-Sub with max. resolution up to 1920x1200 @ 60Hz
  • Supports Auto Lip Sync, Deep Color (12bpc), xvYCC and HBR (High Bit Rate Audio) with HDMI 1.4 Port (Compliant HDMI monitor is required)
  • Supports HDCP 2.3 with HDMI 1.4 Port
  • Supports 4K Ultra HD (UHD) playback with HDMI 1.4 Port
*Intel UHD Graphics Built-in Visuals and the VGA outputs can be supported only with processors which are GPU integrated.
**VP9 10bit and VC-1 are for decode only.
VP8 and VP9 encode are not supported by Windows OS.
Graphics HDV :
  • Hardware Accelerated Codecs: AVC / H.264, HEVC / H.265 8bit, HEVC / H.265 10bit, VP8, VP9 8bit, VP9 10bit, MPEG 2, MJPEG, VC-1**
- Three graphics output options: D-Sub, DVI-D and HDMI***
- Supports HDMI 1.4 with max. resolution up to 4K x 2K (4096x2160) @ 30Hz
- Supports DVI-D with max. resolution up to 1920x1200 @ 60Hz
  • Supports HDCP 2.3 with DVI-D and HDMI 1.4 Ports
***Supports up to 2 displays simultaneously
In the other specifications they are the same what is the price difference ?
  • 1 x D-Sub Port
  • 1 x HDMI Port
Rear panel I/O HDV:
  • 1 x D-Sub Port
  • 1 x DVI-D Port
Graphics HVS :
Graphics HDV :
They have no price difference
