What is the difference between PC3-10600 and PC3-10600S?
radibg2
109
I can't find any laptop ram other than my laptop(HP Pavilion dv7 3150EQ)'s ram(2x2GB) which is PC3-10600S, will a laptop ram PC3-10600 work without problem in my laptop? There is no tech information about the motherboard - HP 365C, but the CPU supports up to 8GB(i've checked from ubuntu terminal by sudo dmidecode -t memory and it shows max ram 8GB) and up to 1066mhz.
To answer you actual question correctly. The "S" as in DDR3 10600S for example stands for SO-DIMM which is the size of RAM for Laptops. If you had desktop memory the same RAM would say DDR3 10600. Crucial and other companies have a way of not listing the RAM speed with the "S' because in the title of the RAM you are purchasing it says "SO-DIM' but when you get your RAM it will have the "S" on it if you are buying for a laptop. Maybe it's to confuse you so that you might not realize that you have some RAM laying around that might work.
