[SOLVED] what is the max fan speed that is safe for rx5700?
harley27
83
4
545
what is the max fan speed that is safe I can set this to in the amd driver software? thanks! Mine usually sticks around 80-90C so I want to make the temp lower without buying new stuff, on auto it is about 1200rpm on 38%, I have rx5700 57XL8MFG6 series. thanks 😀
100% if you can deal with the noise. It's possible 100% fan speed could shorten the life of the bearing but it should still last the useful life of the card regardless, better than running the card at 90c anyway. Case airflow is also important in keeping a GPU cool.
